Date/Time: Wed, 19 Aug 2026 23:50:06 +0000
sc.UseGUIAttachedOrderSetting showing 0
View Count: 1855
| [2014-09-26 15:57:20] |
| QnReally - Posts: 188 |
I assume sc.UseGUIAttachedOrderSetting will show a non-zero value if the following is set: http://screencast.com/t/esdaTeIay9G If so, the following code always displays a 0 for sc.UseGUIAttachedOrderSetting regardless of how I change the highlighted values in the Trade Window shown above. Tool.Text.Format("%d-%d", sc.TradeWindowOrderQuantity, sc.UseGUIAttachedOrderSetting)
Am I not understanding this correctly? Thanks. |
| [2014-09-26 18:35:07] |
No, this is not the case.
| [2014-09-26 19:14:36] |
I am in Simulation mode and the sc.TradeWindwoOrderQuantity part shows correctly in the displayed text on the chart but not the sc.UseGUIAttachedOrderSetting part. If I Check or Uncheck the "Use Attach Orders", the text display continues to show 0. However, if I change the order quantity in the Trade Window, the text display reflects the order quantity part correctly.
| [2014-09-26 19:36:22] |
As we indicated that variable will not indicate what the Trade Window is set to.
