Date/Time: Wed, 25 Nov 2026 22:26:16 +0000
Save Chartbook with 2 charts in One as Study.
View Count: 1662
[2025-03-25 07:51:13]
User838995 - Posts: 22
HI,
As the chart image shows that I have 2 charts in one chartbook displaying both charts side by side. These both charts are linked to each other. This is my Main Chartbook which I wish to save as Custom Study so that I can apply these settings or Study collection to any new chart.
I will like to make a ONE Study Collection which will have these both chart setting so that I can replicate/apply these both charts in one go to the new chart and it will look exactly same as in the image. Thank you for your help. K.A.
https://www.sierrachart.com/image.php?Image=1742888136869.png
[2025-03-25 15:18:11]
There is no support for Study Collections that include multiple charts. You would need to save the studies for each chart as their own study collection.
The one option that may work for you, is to duplicate the charts to another chartbook. In this way, you keep the two charts together as you are wanting, but you end up creating additional chartbooks. Refer to the following:
Chart Menu: Duplicate All Charts to Chartbook (Chart menu)
[2025-03-27 07:05:14]
Thank you for responding!
Regardimg the first option, how do I save the study for each chart, and then how do I apply the two studies to both charts so that they are showing side-by-side in one chart?
Thank you very much! I am a newbie. The image of my Chart is in my previous email above.
Thank you!!
[2025-03-27 08:23:07]
Sierra_Chart Engineering - Posts: 25484
For this you need to use Study Collections. Refer to:
Study Collections
Configure the studies on one chart. Save them as a Study Collection, then apply the Study Collection to the other chart.
Date Time Of Last Edit: 2025-03-27 08:24:58
[2025-04-07 06:32:24]
Hi
According to your above instructions for first option,
1. I Configured the studies, 2 charts side by side in one chart. (Please note that both charts have a bit of different configration but being 2 in 1 when I open chartbook# 4, both charts open side by side on screen. Chart image is in my very fist post.
2.Saved as Study Collection. Named it.
3. Opened new chartbook and applied the above Study Collection.
The issue is that It only saves the active chart settings and applies to the new chart. Not both the charts in my chart book# 4. Am I missing a step in between? How do I save both charts settings in a Study collection? Thank you
[2025-04-07 14:47:10]
Study Collections are applied chart-by-chart. There is not a way to have them applied to multiple charts at one time. You need to have the Study Collection as you want it for one of the charts and apply it to that one, and then have another Study Collection that is set as you want it for the other chart and then apply it that one.
