Date/Time: Fri, 03 May 2024 14:49:40 +0000
Interactive Brokers feed does not contain stocks
View Count: 848
[2014-09-22 18:54:18] |
User48122 - Posts: 7 |
I have a standard Sierra demo (FXCM Forex data). Since I am also running IB TWS on my PC, I copied Sierra into another folder, changed DTS and connected to IB TWS. The available symbols through IB feed were presented to me as follows: CFD, Commodity, Forex, Futures, Indexes, Market Stats but no Stocks. Why there are no stocks? |
sierra ib feed no stocks.jpg / V - Attached On 2014-09-22 18:53:04 UTC - Size: 32.67 KB - 359 views |
[2014-09-22 19:26:49] |
You just need to manually enter the stock symbols following the format given here: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
