Date/Time: Sat, 27 Apr 2024 18:44:22 +0000
VbP on Trade DOM
View Count: 926
[2014-09-22 16:10:16] |
User34947 - Posts: 42 |
Is there a way to display on Trade DOM the volume profile of the current bar of a selected bar period? On a chart this can be done selecting Multiple Profiles Fixed by Bar Count as Volume Graph Period Type and 1 as Number of Bars for Fixed Bar Count, but it seems that on Trade DOM it is possible to display only the entire volume profile of the current session. Thank you |
[2014-09-22 16:12:17] |
No, you do need to use a standard chart for this.
