Date/Time: Fri, 03 May 2024 18:33:46 +0000
Cancel external data feed
View Count: 1026
[2014-09-22 15:16:34] |
AG - Posts: 3 |
Hi There, If I want to chart only: ES, NQ, TF = futures, I can get that real time with out external data feed - correct? If so please guide me on how to cancel my external data feed. Thanks ag |
[2014-09-22 15:19:03] |
This requires either an external data feed service, or you can use the Sierra Chart Real-time and Historical Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-22 19:22:29] |
AG - Posts: 3 |
I am sitting on this setup to no success all morning, I had the symbols NQ, ES - futures charting is all I need now, earlier now they are gone I can't find them, and I can't get a real time price chart of them. I know it should be pretty simple..... please send me the proper link. Thanks ag |
[2014-09-22 19:28:25] |
We can assure you that the futures exchanges do not make this simple. This is a good section here to read about this: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME And we did give you the proper information and instructions. Here they are again: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Do you have a futures trading account? If so, with what trading service? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-22 19:29:27
[2014-09-22 19:40:47] |
AG - Posts: 3 |
Hi There & thanks for the speedy reply!! I am trading future via InterActive broker = IB IS it best to set IB as the data feeder? if so will I have to pay Sierra for that? THANKS again ag |
[2014-09-22 20:19:57] |
In this case follow the set up instructions here for Interactive Brokers. http://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions You do need to pay for Sierra Chart as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
