Date/Time: Sun, 12 May 2024 00:47:23 +0000
Version 1192 - I cannot run replay the charts?
View Count: 1244
[2014-09-21 15:03:34] |
FFTrader - Posts: 180 |
Just updated to Version 1192 and the replay function just hangs and will not run? What gives? |
[2014-09-21 16:32:05] |
You may be trying to start a replay a point in time where there is no trading activity. Try increasing the replay speed to 1000. Make sure you to follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#BasicInstructions Replay works fine in 1192. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-27 17:01:53] |
Well, this is really strange. The replay used to work yesterday - and now it does not work!? Same problem. It just hangs there with no charts and with the message "Downloading Continuous Contract Data". Now I don't know why as I was just trying to replay the charts - and the continuous contract data should have been downloaded already? HELP!!!! |
[2014-09-27 17:19:05] |
Here is what it looks like on my screen. Data supplier is Interactive Brokers. |
Capture SC.PNG / V - Attached On 2014-09-27 17:18:31 UTC - Size: 124.25 KB - 358 views |
[2014-09-27 18:37:03] |
There appears to be an IB issue with the downloading of historical data. Therefore, disable the Continuous Futures Contract option on the charts you are replaying.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-27 18:37:14
[2014-09-27 19:41:50] |
Ah, why is historical data not already downloaded into the data files? I can see those *.scid files growing bigger everyday? If nothing else, I want to work with the replay of charts and historical data even without an Internet connection. Moreover, it does not work without connecting to the Internet - but in the past it works even without internet connection. Please fix as it is critical for back testing. Date Time Of Last Edit: 2014-09-27 20:23:56
[2014-09-27 20:24:51] |
We cannot say without careful examination of the log and we are not going to do that being you are using IB data. Working with IB historical data is a struggle and we will not provide support for that. And even though the reliance on the Interactive Brokers historical data has been minimized in newer versions of Sierra Chart, it is still used. Therefore, the proper solution is to use the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed The general procedure to resolve an incomplete data issue with a Continuous Futures Contract chart is to re-download the data as explained here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Do that and see if it resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-27 20:28:56
[2014-09-27 20:28:36] |
There were various dictation errors in the prior post and they have now been corrected. Reload this page in your browser. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-27 20:37:14] |
We do see an attempt to download historical daily data for the current futures contract under some conditions, on every reload of the chart and we will see why that is happening. However, even if you do not have an Internet connection, the download fails and the chart will load after. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-27 20:37:35
[2014-09-27 20:53:00] |
This is now fixed: We do see an attempt to download historical daily data for the current futures contract under some conditions, on every reload of the chart and we will see why that is happening.
However, it does not make sense why it would manifest in an ongoing message that you saw on the charts indicating the continuous futures contract data is being downloaded. There will be a new release out tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-27 21:35:58] |
May be if I summarize it, it may help as it appears that it is working perfectly fine on my 1187 version installed on another computer. 1. After your first reply above, it seems to work fine without me doing anything. That was about a week ago. 2. The problem started again today. But I did not keep track of the timing as to whether it is weekends only. It could have started last night after all markets closed. 3. Yes, the screen shot I sent above just persists and nothing changes - I have to close the program. 4. Version 1187 still works with replay - with or without internet connection and with or without connection to IB. 5. Version 1192 works with stocks data and replay would run normally. Hope it helps. |
[2014-09-27 21:38:21] |
Refer to our additional postings made before your post #11.
[2014-09-27 21:47:14] |
I did. Just waiting for tomorrow's update while providing more information.
[2014-09-27 22:54:45] |
We did not need any further information.
[2014-09-28 00:21:45] |
Oh ok ...
[2014-09-28 00:55:38] |
We have released a new revision of 1196 just now. Update by selecting Help >> Download Prerelease.
[2014-09-29 02:00:11] |
Okay! Thanks for all the work on the weekend!
[2014-09-29 14:35:00] |
ertrader - Posts: 645 |
There appears to still be an issue with replay. When I replay, the following picture appears until I exit Sierrachart 1) I am currently using Version 1196 2) This started a couple versions ago.. not sure which one but thought it would be fixed so did not bring it up 3) Happens whether I am connected to IB or not 4) Must restart SC to get back to normal 5) This happens with NO studies attached to the chart being replayed 6) I select replay all charts 7) My settings are below 8) There are no errors in the log file 9) Reproducible every time so replay is not functional at all http://www.sierrachart.com/image.php?l=141200119654.png Date Time Of Last Edit: 2014-09-29 14:45:29
replay.png / V - Attached On 2014-09-29 14:36:52 UTC - Size: 31.1 KB - 358 views |
[2014-09-29 14:46:47] |
This means data is being downloaded . So the question is why is the download not completing. Restart Sierra Chart, open only one single chart and no other charts. Start a replay of that chart and if you see that message on the chart window for more than a minute, then post a copy of the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-29 14:47:57
[2014-09-29 15:00:40] |
1) Replay for one chart works fine. 2) As soon as I add 1 more chart, the problem exists 3) Attached is my test chart file. No studies 4) Happens whether connected to IB or not 5) After waiting 2 minutes, not connected to IB, no change Below is my log: Software version: 1196 | 2014-09-29 10:58:04 Usage end date: 2015-06-03 | 2014-09-29 10:58:04 Enabled for: Advanced Features. | 2014-09-29 10:58:04 Enabled for: Sierra Chart Historical Data Service. | 2014-09-29 10:58:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-09-29 10:58:04 Active service: Interactive Brokers | 2014-09-29 10:58:04 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-09-29 10:58:04 2014-09-29 09:58:04 Local computer clock time | 2014-09-29 10:58:04 2014-09-29 14:58:04 GMT time | 2014-09-29 10:58:04 2014-09-29 10:58:04 Time zone adjusted time | 2014-09-29 10:58:04 Time difference to server time: 31 seconds. | 2014-09-29 10:58:04 WARNING: Your computer's clock is off by 31 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-09-29 10:58:04 Program path: C:\SierraChart\ | 2014-09-29 10:58:04 Data Files path: D:\Sierra_Data\ | 2014-09-29 10:58:04 OS Version Number: 6.1 | 2014-09-29 10:58:04 Checking for new symbol settings for ib | 2014-09-29 10:58:04 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-29 10:58:04 HTTP connection to www.sierrachart.com:80 (880) | Connected. | 2014-09-29 10:58:04 Symbol settings are up-to-date for ib | 2014-09-29 10:58:04 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:06 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:06 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:06 NQ-201409-GLOBEX | 2014-09-29 10:58:06 NQ-201412-GLOBEX | 2014-09-29 10:58:06 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:06 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:06 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:06 NQ-201409-GLOBEX | 2014-09-29 10:58:06 NQ-201412-GLOBEX | 2014-09-29 10:58:06 HD Request # 2 | Downloading Historical Daily chart data for NQZ14. Starting date: 2014-09-26. Service: ib | 2014-09-29 10:58:06 HD Request # 2 | Requesting historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:06 HD Request # 2 | Receiving historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:06 Writing historical Daily data for NQZ14 to the file NQZ14.dly | 2014-09-29 10:58:06 HD Request # 2 | Received 3 records from 2014-09-25 00:00:00 to 2014-09-29 00:00:00 (5.0 days) and wrote 2 records for NQZ14 | 2014-09-29 10:58:06 HD Request # 2 | Daily download COMPLETE for NQZ14. Completion time: 0s | 2014-09-29 10:58:06 Checking for large (over 289 MB) intraday data files to move data out of. Please wait.... | 2014-09-29 10:58:06 Completed checking of 69 Intraday data files (*.scid). | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Performing continuous futures contract back adjustment calculations. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201409-GLOBEX Open price on 2014-09-11 is 4093. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201412-GLOBEX Open price on 2014-09-11 is 4086.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201409-GLOBEX price difference to NQ-201412-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Back adjust amount for symbol NQ-201409-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Performing continuous futures contract back adjustment calculations. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201409-GLOBEX Open price on 2014-09-11 is 4093. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201412-GLOBEX Open price on 2014-09-11 is 4086.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201409-GLOBEX price difference to NQ-201412-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Back adjust amount for symbol NQ-201409-GLOBEX is -6.5. | 2014-09-29 10:58:06 HTTP connection to www.sierrachart.com:80 (880) | Closed. No error. | 2014-09-29 10:58:14 HTTP connection to www.sierrachart.com:80 (880) | Shutdown and closed. | 2014-09-29 10:58:14 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:23 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:23 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:23 NQ-201409-GLOBEX | 2014-09-29 10:58:23 NQ-201412-GLOBEX | 2014-09-29 10:58:23 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:23 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:23 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:23 NQ-201409-GLOBEX | 2014-09-29 10:58:23 NQ-201412-GLOBEX | 2014-09-29 10:58:23 HD Request # 3 | Downloading Historical Daily chart data for NQZ14. Starting date: 2014-09-26. Service: ib | 2014-09-29 10:58:23 HD Request # 3 | Requesting historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:23 HD Request # 3 | Receiving historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:23 Writing historical Daily data for NQZ14 to the file NQZ14.dly | 2014-09-29 10:58:23 HD Request # 3 | Received 3 records from 2014-09-25 00:00:00 to 2014-09-29 00:00:00 (5.0 days) and wrote 2 records for NQZ14 | 2014-09-29 10:58:23 HD Request # 3 | Daily download COMPLETE for NQZ14. Completion time: 0s | 2014-09-29 10:58:23 |
Attachment Deleted. Test.cht - Attached On 2014-09-29 15:00:01 UTC - Size: 39.35 KB - 380 views |
[2014-09-29 15:02:10] |
After connecting log. Software version: 1196 | 2014-09-29 10:58:04 Usage end date: 2015-06-03 | 2014-09-29 10:58:04 Enabled for: Advanced Features. | 2014-09-29 10:58:04 Enabled for: Sierra Chart Historical Data Service. | 2014-09-29 10:58:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-09-29 10:58:04 Active service: Interactive Brokers | 2014-09-29 10:58:04 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-09-29 10:58:04 2014-09-29 09:58:04 Local computer clock time | 2014-09-29 10:58:04 2014-09-29 14:58:04 GMT time | 2014-09-29 10:58:04 2014-09-29 10:58:04 Time zone adjusted time | 2014-09-29 10:58:04 Time difference to server time: 31 seconds. | 2014-09-29 10:58:04 WARNING: Your computer's clock is off by 31 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-09-29 10:58:04 Program path: C:\SierraChart\ | 2014-09-29 10:58:04 Data Files path: D:\Sierra_Data\ | 2014-09-29 10:58:04 OS Version Number: 6.1 | 2014-09-29 10:58:04 Checking for new symbol settings for ib | 2014-09-29 10:58:04 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-29 10:58:04 HTTP connection to www.sierrachart.com:80 (880) | Connected. | 2014-09-29 10:58:04 Symbol settings are up-to-date for ib | 2014-09-29 10:58:04 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:06 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:06 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:06 NQ-201409-GLOBEX | 2014-09-29 10:58:06 NQ-201412-GLOBEX | 2014-09-29 10:58:06 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:06 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:06 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:06 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:06 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:06 NQ-201409-GLOBEX | 2014-09-29 10:58:06 NQ-201412-GLOBEX | 2014-09-29 10:58:06 HD Request # 2 | Downloading Historical Daily chart data for NQZ14. Starting date: 2014-09-26. Service: ib | 2014-09-29 10:58:06 HD Request # 2 | Requesting historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:06 HD Request # 2 | Receiving historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:06 Writing historical Daily data for NQZ14 to the file NQZ14.dly | 2014-09-29 10:58:06 HD Request # 2 | Received 3 records from 2014-09-25 00:00:00 to 2014-09-29 00:00:00 (5.0 days) and wrote 2 records for NQZ14 | 2014-09-29 10:58:06 HD Request # 2 | Daily download COMPLETE for NQZ14. Completion time: 0s | 2014-09-29 10:58:06 Checking for large (over 289 MB) intraday data files to move data out of. Please wait.... | 2014-09-29 10:58:06 Completed checking of 69 Intraday data files (*.scid). | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Performing continuous futures contract back adjustment calculations. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201409-GLOBEX Open price on 2014-09-11 is 4093. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201412-GLOBEX Open price on 2014-09-11 is 4086.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: NQ-201409-GLOBEX price difference to NQ-201412-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 4t #1: Back adjust amount for symbol NQ-201409-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Performing continuous futures contract back adjustment calculations. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201409-GLOBEX Open price on 2014-09-11 is 4093. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201412-GLOBEX Open price on 2014-09-11 is 4086.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: NQ-201409-GLOBEX price difference to NQ-201412-GLOBEX is -6.5. | 2014-09-29 10:58:06 NQ-201412-GLOBEX/NQ-201412-GLOBEX [CB] Renko 12t #2: Back adjust amount for symbol NQ-201409-GLOBEX is -6.5. | 2014-09-29 10:58:06 HTTP connection to www.sierrachart.com:80 (880) | Closed. No error. | 2014-09-29 10:58:14 HTTP connection to www.sierrachart.com:80 (880) | Shutdown and closed. | 2014-09-29 10:58:14 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:23 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:23 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:23 NQ-201409-GLOBEX | 2014-09-29 10:58:23 NQ-201412-GLOBEX | 2014-09-29 10:58:23 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-09-29 10:58:23 Date rule based rollover from NQ-201412-GLOBEX to next contract occurs at 2014-12-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-09-29 10:58:23 Checking Intraday data file for symbol NQ-201412-GLOBEX for the date range from 2014-09-11 to 0. | 2014-09-29 10:58:23 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-09-29. | 2014-09-29 10:58:23 Symbols used for NQ-201412-GLOBEX continuous contract chart: | 2014-09-29 10:58:23 NQ-201409-GLOBEX | 2014-09-29 10:58:23 NQ-201412-GLOBEX | 2014-09-29 10:58:23 HD Request # 3 | Downloading Historical Daily chart data for NQZ14. Starting date: 2014-09-26. Service: ib | 2014-09-29 10:58:23 HD Request # 3 | Requesting historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:23 HD Request # 3 | Receiving historical Daily data for NQZ14 starting at 2014-09-25 | 2014-09-29 10:58:23 Writing historical Daily data for NQZ14 to the file NQZ14.dly | 2014-09-29 10:58:23 HD Request # 3 | Received 3 records from 2014-09-25 00:00:00 to 2014-09-29 00:00:00 (5.0 days) and wrote 2 records for NQZ14 | 2014-09-29 10:58:23 HD Request # 3 | Daily download COMPLETE for NQZ14. Completion time: 0s | 2014-09-29 10:58:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-09-29 11:01:54 Socket (688) | Connected. | 2014-09-29 11:01:54 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-09-29 11:01:54 Interactive Brokers | TWS server version: 70 | 2014-09-29 11:01:55 Interactive Brokers | Connected. Waiting for account information. | 2014-09-29 11:01:55 IB Account information received. | 2014-09-29 11:01:55 Interactive Brokers | Connected to Live account. | 2014-09-29 11:01:55 Interactive Brokers | Year-Month last connected to Live account: 2014-09 | 2014-09-29 11:01:55 Interactive Brokers | Requesting Trade Positions for account: * | 2014-09-29 11:01:55 Next valid order ID: 268 | 2014-09-29 11:01:55 Message from IB: Market data farm connection is OK:usbond. IB Error Code: 2104. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-09-29 11:01:55 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2014-09-29 11:01:55 Next valid order ID: 268 | 2014-09-29 11:01:55 IB Account information received. | 2014-09-29 11:01:55 Interactive Brokers | Connected to Live account. | 2014-09-29 11:01:55 Interactive Brokers | Year-Month last connected to Live account: 2014-09 | 2014-09-29 11:01:55 Interactive Brokers | Received Trade Positions download end message for account * | 2014-09-29 11:01:55 Interactive Brokers | Requesting historical order fills for account *. | 2014-09-29 11:02:00 Interactive Brokers | Received Open orders end message. | 2014-09-29 11:02:00 Date Time Of Last Edit: 2014-09-29 16:54:57
[2014-09-29 15:03:59] |
Replay settings
replay_Settings.png / V - Attached On 2014-09-29 15:03:50 UTC - Size: 7.71 KB - 358 views |
[2014-09-30 04:40:26] |
From what we can tell this problem has already been fixed but you have an older revision. Update Sierra Chart again by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-30 04:43:17] |
Yes, downloaded the Prerelease version and it worked today.
