Date/Time: Sun, 05 May 2024 15:53:00 +0000
round method in spreadsheet
View Count: 1982
[2014-09-18 22:47:31] |
onnb - Posts: 661 |
the spreadsheets have a method called ROUND(number, digits) is this rounding up/down or to the nearest? is there an equivalent acsil method to this one? is sc.RoundToTickSize(x, 0.001) the same as ROUND(x, 3)? |
[2014-09-18 23:35:10] |
Sawtooth - Posts: 3993 |
the ROUND function rounds to the nearest, either up or down. To round to tick size, use the MROUND function: =MROUND(n,$J$21) If J21 has floating point errors, you can eliminate them with this in H21: =1/ROUND(1/J21,0) then use: =MROUND(n,$H$21) The MROUND function rounds to the nearest multiple, either up or down. Date Time Of Last Edit: 2014-09-19 01:21:58
[2014-09-19 02:23:50] |
onnb - Posts: 661 |
thanks, sorry for not being clear enough converting a spreadsheet to acsil, the sheet uses rounding to compare #'s like so: ROUND(x, 3) > ROUND(y, 3) I am looking for the acsil equivalent of that I hope this is more clear |
[2014-09-19 13:20:38] |
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scRoundToTickSize From the documentation: sc.RoundToTickSize() takes a float and rounds it to the nearest increment. This would be the same as the spreadsheet MROUND function. http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scRound From the documentation: sc.Round() takes a float and rounds it to the nearest int. This is different than the spreadsheet ROUND function. It appears there is no directly equal ACSIL member function. Date Time Of Last Edit: 2014-09-19 13:22:58
[2014-09-19 18:31:27] |
We will add the ACSIL equivalent.
[2014-09-19 19:15:29] |
In the next release this function will be added: double sc.RoundToIncrement(double Value, float TickSize) However, it is equivalent to: sc.RoundToTickSize Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-20 01:36:45] |
onnb - Posts: 661 |
from previous response MROUND(E3, J$21) == sc.RoundToTickSize(sc.BaseData[SC_LAST][sc.Index], sc.TickSize) I am seeing that for some values, this is not the case. e.g., for 1.296649933 mround = 1.2966 roundtoticksize = 1.2967 Just want to confirm that this is expected. |
[2014-09-22 04:04:58] |
Yes because sc.RoundToTickSize has a more practical implementation that makes adjustments for floating-point error: double RoundToTickSize(double Value, double TickSize)
{ if (TickSize == 0) return Value; // cannot round double ClosestMult = (int)(Value / TickSize) * TickSize; double Diff = Value - ClosestMult; double DifferenceFromIncrement = TickSize*0.5 - Diff; double Result; if (Value > 0.0 && DifferenceFromIncrement <= TickSize * 0.001) Result = ClosestMult + TickSize; else if (Value < 0.0 && DifferenceFromIncrement <= TickSize * 0.001) Result = ClosestMult - TickSize; else Result = ClosestMult; return Result; } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
