Date/Time: Tue, 30 Apr 2024 06:57:38 +0000
Trade dom setting: last size column: have the options combinated recorded like in the T&S
View Count: 948
[2014-09-18 21:24:34] |
sierra28 - Posts: 120 |
because most of the time i have 1 last size volume in my DOM or in the T&S in which i've choosed combine records, last volume traded are higher.A solution would be that Last size volume in the dom combine records like in the T&S that user have selected. Possible to color last size number in green or red (user's ask & bid color) depending if it is a ask or bid last volume traded. thanks. Date Time Of Last Edit: 2014-09-18 21:40:24
[2014-09-26 09:10:25] |
an issue at the problem of difference last size volume in dom and T&S ? thanks |
[2014-10-02 15:21:36] |
hello, so why is there a difference beetween last size volume in a dom and T&S thanks |
[2014-10-02 15:25:56] |
Are you using any options in the Time and Sales window to combine trades? If so, this is the problem.
[2014-10-02 16:16:56] |
yes i use an option to combinate price? should it be possible to have same option in dom because most of time the last volume in dom is 1 , so no interest. |
