Date/Time: Thu, 02 May 2024 02:33:01 +0000
Cross hairs
View Count: 832
[2014-09-18 20:25:05] |
User54027 - Posts: 128 |
Support, This never used to be the case but the crosshairs seem to now be a permanent feature of the charts. I cannot find a way to turn them off. Even when using hand tool they are on. Pleaee. Please. Can we go back to how things where. When you wanted the crosshairs you asked for em. So easy. So simple. Thank you. |
[2014-09-18 20:30:54] |
This has been resolved in the latest release of Sierra Chart. You can update through the Help menu.
