Date/Time: Sat, 04 May 2024 04:29:49 +0000
Need Bar Range Calculation
View Count: 1097
[2014-09-18 18:50:13] |
Handle - Posts: 36 |
Using 30 min VbP typical footprint style and associated Calculated Values study below main graph. I want to be able to capture the 30 min bar range in the calculated values. All I see available in the study is Daily Range. Is there a simple way to get the 30 min bar range data included? |
[2014-09-19 01:19:15] |
You can set the chart bars to 30 minutes per bar and then use the Bar Difference study.
[2014-09-19 11:50:59] |
Ok that's a work around to get the data. But, when I use the draw style of Value of Subgraph I get the numerical bar difference which was the goal but it plots the number like it was on a line graph and thus takes up a bunch of room in the chart region. Is there anyway to simply have the bar difference numbers print out in a horizontal line much like is done with all the other number bar calculated values? |
[2014-09-19 12:12:47] |
We will add this to the next release. In the Numbers Bars Calculated Values study you will see this new Subgraph: High-Low Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
