Date/Time: Fri, 03 May 2024 00:17:13 +0000
DOM data disappeared from the NumbersBars chart
View Count: 798
[2014-09-18 15:48:27] |
Kefir - Posts: 34 |
cca 8 min ago DOM data (i.e. bid ask volume sizes on particular levels) disappeared from the NumbersBars chart. I didnt change anything in my charts Common issue or just mine? SC restarted... it appears now bye Date Time Of Last Edit: 2014-09-18 15:59:06
[2014-09-18 18:48:22] |
We need to see an image of the chart when you see this and know if there is any volume filtering set. Here are the instructions to post an image: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
