Date/Time: Wed, 08 May 2024 01:54:52 +0000
[User Discussion] - Help with Study Set Woodies for Range Charts PP New
View Count: 883
[2014-09-18 13:40:32] |
djcurcio - Posts: 236 |
I set as chart with Woodies for Range Charts PP New Study Set. Two questions. 1. Does this work with Time-based and Tick-based charts? 2. I cannot seem to change the background color regardless of changing the Chart>Graphics Setting>Chart Background and Unchecking the "Use Global Graphics Setting" checkbox. How to change the chart background for this? Thanks |
[2014-09-19 18:25:37] |
1. Not completely. 2. The background color is controlled through the Woodies Panel . You need to set the Use Woodies Background Color input to No, to be able to separately control the color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-19 18:27:01
[2014-09-19 19:41:27] |
I found the background color control on the Study>Settings Woodies Panel by SC - "Background Colors" This is a two option color box of Custom Text definition. What parameter(s) control the changing of the background color? Is there more detailed documentation of this study set/ Thanks |
