Date/Time: Thu, 19 Nov 2026 12:33:28 +0000
Candle Stick Volume Chart not the same in different accounts
View Count: 543
[2025-01-27 19:22:10]
MM1304 - Posts: 2
Hey there,
my wife and i using Sierra Chart for analysis. We analyse NQ with 2000 Volume chart. We have set up everything equal. Despite this we have different Volume candles in the Chart, how is this possible?
In my chart some candles are sell candles (black) in her chart they are buy candles (white). Or she has dojis and i have normal candles. See attached charts.
https://www.sierrachart.com/image.php?Image=1738005559349.png
https://www.sierrachart.com/image.php?Image=1738005540118.png
How is this possible?
Best regards,
Simon
imageAnni_1.jpg / V - Attached On 2025-01-27 18:45:58 UTC - Size: 39.13 KB - 138 views
imageSimon_1.png / V - Attached On 2025-01-27 18:46:18 UTC - Size: 22.54 KB - 230 views
imageAnni_2.jpg / V - Attached On 2025-01-27 18:49:10 UTC - Size: 3.96 KB - 216 views
[2025-01-27 20:03:25]
Refer to:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
We also recommend you use the Denali Exchange Data Feed for data instead of Rithmic:
