Date/Time: Sun, 12 May 2024 22:56:32 +0000
Indicator Numbers Bars Calculated Values using filtering.
View Count: 1651
[2014-09-18 02:15:53] |
2garin - Posts: 184 |
Good day. Trying to build a chart similar to MD (140916 MD). Built Reversal Bar 6tiks chart (c1). Add and configure indicator Numbers Bars. Add and configure indicator Numbers Bars Calculated Values (140916 SC). For zero values of Volume Filter (c2) indicator Numbers Bars Calculated Values identical to the MD. At the opening of the copies of the chart with the installation of the values (49, 99, 249) in Volume Filter Indicator Numbers Bars Calculated Values with significant differences (140916 SC 49, SC 99 140916, 140916 SC 249). Please tell me the possible cause of the discrepancies. |
Private File Private File Private File Private File Private File Private File Private File Private File |
[2014-09-18 03:10:47] |
We do not understand the question.
[2014-09-18 04:27:50] |
The question seems to be about the Volume Filter and this is documented here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VolumeFilterH Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-18 04:45:13] |
I want to add to the chart indicator Numbers Bars Calculated Values for ALL trades, or trades of a certain size (50, 100, 250 lots). Adding indicator without filtering trades I get identical indicator MD. When you select a filter trades there are any differences. Error in the algorithm indicator or in selected settings? |
[2014-09-19 01:37:47] |
We think we understand what you are referring to. The volume filtering only removes the volume from the trade and does not remove the trades themselves. So we need to add an option to remove the trade that meets the volume filter conditions. This will be available in about a week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-19 01:38:43
[2014-09-19 03:37:57] |
Please let me know after the implementation. Thank you. |
[2014-09-19 13:41:58] |
This will be out in version 1193 which will be out over the weekend or on Monday. You will see "Filter Trade Completely" in the Volume Filter setting in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-23 08:32:34] |
ganz - Posts: 1048 |
Hello SC Support So we need to add an option to remove the trade that meets the volume filter conditions.
There was my old request as well. so +1. thnx. |
[2014-09-23 09:08:37] |
Yes, we think we remember this. This has been released. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-23 11:33:02] |
SC Support Looks good. Thnx. FYI: some traders are using NumberOfTrades@Bid x NumberOfTrades@Ask for a short term analisys in order to indentify a micro trend http://www.youtube.com/watch?v=ziSgMqiDCL8 so is it possible for you to add an option: Column # Numbers Bars Text: Bid Trds x Ask Trds ? ps: this qstn is from another user thnx. |
[2014-09-27 11:15:53] |
Hello support. Pay attention to the calculation of the average of volume and number of trades. Differences remained. Thank you. |
[2014-09-29 01:46:14] |
Column # Numbers Bars Text: Bid Trds x Ask Trds ? No, this is not possible without increasing memory use for all users.
[2014-09-29 02:08:19] |
Pay attention to the calculation of the average of volume and number of trades. Differences remained. Refer to the updated documentation here about this: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#VolumeFiltering Be sure to enable the Filter Trade Completely option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
