Date/Time: Thu, 19 Nov 2026 12:33:11 +0000
How to display tick level volume on a daily chart?
View Count: 1038
| [2025-01-25 20:04:06] |
| warpigs - Posts: 83 |
How can I display tick level volume data on a historical daily chart?
| [2025-01-25 21:23:05] |
| Sierra_Chart Engineering - Posts: 25441 |
You cannot. It is necessary to use an Intraday chart for this. Refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-25 21:23:15
| [2025-01-25 21:51:36] |
Thanks. So would it be possible to use an intraday bar chart that displays tick level volume data, but is 24 hour bars in order to have the chart display daily bars?
| [2025-01-25 22:22:33] |
| cmet - Posts: 746 |
Have you tried opening an Intraday chart and setting the number of days to 1?
| [2025-01-25 23:08:12] |
Yes, refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-25 23:16:34] |
Thanks all. Yes I have currently selected an intraday chart and set the day number to 1. I am assuming that means it will display a bar that shows the full 24 hour session. I was just wondering if this is the proper way to get tick level volume data to display with daily bars, or if there is a better workaround.
| [2025-01-26 00:30:39] |
| cmet - Posts: 746 |
A quick way to get 24 hour, open to open bars is to: 1. Select Intraday 2. Use 1 Day or 1440 minutes 3. Change Chart Settings > Session Times to the start and end times you want. For example, with U.S. markets: Start time: 9:30:00 End time: 9:29:59 Evening Session: No Date Time Of Last Edit: 2025-01-26 00:31:05
| [2025-01-26 00:45:42] |
Thanks, but why would I exclude the evening session? If I do that, it wouldn’t be a full 24 hour session bar, right?
| [2025-01-26 12:59:58] |
| cmet - Posts: 746 |
How can a 24 hour period not include the evening session? You're overthinking it. |
| [2025-01-26 14:12:55] |
Thanks, but I don’t understand. You said to set evening session to “no“. Wouldn’t that exclude it?
| [2025-01-27 21:24:31] |
| John - SC Support - Posts: 48583 |
They stated to set the Evening Session to "No" because the primary session start and end times cover the full 24 hour period, so there is no need to specify a separate Evening Session.
