Date/Time: Thu, 02 May 2024 10:19:37 +0000
Can one overlay two OSC indicators together?
View Count: 1141
[2014-09-17 19:57:19] |
User93103 - Posts: 48 |
Hello: Is it possible to overlay two OSC indicators (studies) on each other in Sierra Chart? For example, putting both Stochastic Momentum Indicator and Volume Zone OSC, since, they both have ranges from +100 to -100. Thank You God Bless Ben |
[2014-09-18 06:22:05] |
Yes, this can be done and is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#OverlayingStudiesOnSameChartRegion Even if the scales are different you can still put them in the same Chart Region by setting the Scale Range for one of them to Independent. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
