Date/Time: Mon, 29 Apr 2024 01:20:30 +0000
Tool question
View Count: 981
[2014-09-17 18:13:05] |
trader1 - Posts: 128 |
Hi, Is there a tool that draws three extended parallel lines at one time and can be moved as a group? Thanks. |
[2014-09-17 18:55:00] |
Yes, the Parallel Rays tool. We are going to be reviewing and updating the documentation for this today.
[2014-09-17 19:24:52] |
Okay thanks. I tried this tool and was only able to get two parallel lines not three.
[2014-09-18 04:25:39] |
We have updated the documentation for Parallel Rays here: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ParallelRays You need to add additional lines through Level % settings in the Parallel Ray configuration window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-18 13:57:35] |
Hi, I tried that earlier and I have attached a screenshot of how I configured the settings, but I still get only two lines. Also will the parallel lines tool do the same thing? Thanks |
sierrachart parallel rays settings.gif / V - Attached On 2014-09-18 13:57:02 UTC - Size: 13.78 KB - 355 views |
[2014-09-18 18:23:33] |
A 100% level will not show an additional line. That will be drawn right on top of the second line. The documentation does explain this. How far away, as a percentage, from the two parallel lines do you want additional lines? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-18 18:23:53
[2014-09-18 19:02:48] |
Actually, what I would like is three parallel lines equidistant from each other (i.e. one line five points above the middle line and another line five points below the middle line). I would also like these three lines to move as a group if I select "move drawing" from the menu. Thanks. |
sierrachart three parallel lines.jpg / V - Attached On 2014-09-18 19:02:36 UTC - Size: 31.07 KB - 353 views |
[2014-09-18 19:09:24] |
Set the third Level % to 200.
