Date/Time: Fri, 03 May 2024 14:40:27 +0000
Start - End time
View Count: 1147
[2014-09-16 04:33:19] |
User120827 - Posts: 77 |
When you add certain trade hours to your code, how do you start at 18:00 on one day, and continue to the close of the next day at 5:15 ? I have only been able to establish trading hours for the current day so far. regards shane |
[2014-09-16 18:06:54] |
Here is a code example: if(sc.BaseDateTimeIn[sc.Index].GetTime() > HMS_TIME(18,0,0) ||
sc.BaseDateTimeIn[sc.Index].GetTime() < HMS_TIME(5, 15,0)) { } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-10 09:00:58
[2021-01-10 08:46:02] |
User719512 - Posts: 227 |
The && should be an || I believe. if(sc.BaseDateTimeIn[sc.Index].GetTime() > HMS_TIME(18,0,0) || sc.BaseDateTimeIn[sc.Index].GetTime() < HMS_TIME(5, 15,0)) { } |
[2021-01-10 09:01:03] |
Yes that is correct, it has been corrected.
