Date/Time: Thu, 19 Nov 2026 11:17:23 +0000
Tick increment Market Profile and Volume Profile
View Count: 759
[2024-12-07 16:26:45]
VenoYoTiK - Posts: 30
is there a possibility to have a 2er Tick Increment in the Market Profile while at the same time have a 1er Tick Increment at the Volume Profile?
I can make them different but then I can not have a Daily Volume Profile.
Thank for the help.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=110837
imageScreenshot 2024-12-07 at 17.25.20.png / V - Attached On 2024-12-07 16:26:31 UTC - Size: 1022.93 KB - 312 views
[2024-12-09 15:53:31]
When you are dealing with a Volume by Price profile that is connected to a TPO profile (i.e. Volume Graph Period Type is set to "Based on TPO Profile") then the "Ticks per Volume Bar" is defined by what is being used by the TPO Profile. There is no way to change this.
If the Volume by Price study is separate from the TPOs (i.e. a single profile to the right), then this can have any "Ticks per Volume Bar" setting.
[2024-12-09 17:50:33]
Ok and is it possible to have a daily volume profile, for every single day that is loaded, if it is separate?
[2024-12-09 19:42:06]
There is not an automated way to have a daily separate Volume by Price profile separate from the TPOs. You would have to create individual Volume by Price profile and each one has to be independent from the TPO and they then will be right-aligned (not next to the individual TPOs for that day).
