Date/Time: Thu, 19 Nov 2026 11:17:27 +0000
Market profile
View Count: 674
[2024-12-04 12:04:05]
User266447 - Posts: 280
I kindly ask for your assistance. In the attached file, I am unable to compress or extend (make larger) the market profile, nor can I make it thinner (narrower). I wanted to have more market profiles displayed on one monitor, but I cannot achieve this. Either the profiles extend beyond the screen and I cannot compress them, or they are too large, and I only see a few on the screen. I need to make them thinner to have a broader historical range visible on one screen. I am attaching the chartbook (CHT file) — thank you for your help. Perhaps, if you take a look at the chartbook attatched, you could immediately apply the necessary changes so I can use it in the form I need? Thank you in advance for your assistance.
attachmentMarketProfile-abc.Cht - Attached On 2024-12-04 12:01:25 UTC - Size: 8.99 KB - 418 views
[2024-12-04 18:19:13]
To view more TPO profiles, you need to change the Bar Spacing. Refer to the following:
Working With Charts: Changing Bar Spacing
[2024-12-05 16:23:56]
Thank you. What about the vertical scale? How can I flatten or extend the market profile chart? How can I change it? I would appreciate some guidance on this matter (I have already learned how to stretch it horizontally).
[2024-12-05 16:53:04]
That would be done by adjusting the vertical scale. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scaling
