Date/Time: Sun, 05 May 2024 10:00:50 +0000
Reset Scales via ACSIL
View Count: 982
[2014-09-12 03:12:05] |
QnReally - Posts: 181 |
Is it possible to do what "Chart -> Reset Scales" does via ACSIL? I have a custom study that has a constant range scale of its own and I have ACS buttons to adjust the y-position of the graph up or down. The buttons work great but I have to then double-click on the y-scale to re-center the graph. Not a big deal but thought I'd ask. Thanks. |
[2014-09-13 02:34:06] |
We can add this capability. This will be out in the next release.
[2014-10-12 14:57:12] |
Hendrixon - Posts: 130 |
Was this option added? Can't find any documentation. |
