Date/Time: Thu, 19 Nov 2026 11:16:59 +0000
ISSUE: Study Subgraph Above/Below Bar as Text - Not Working
View Count: 616
[2024-12-04 03:06:07]
User708541 - Posts: 213
For my numbers bars (Range Bars), I wanted to have text under each bar indicating the duration of the bar. As you can see, this data displays properly in the Number Bars Calculated Value, but once I use the study, Study Subgraph Above/Below as Text, the values do not translate. See enclosed images.
imageBar Duration Not Working as Text Under Bar_Settings.jpg / V - Attached On 2024-12-04 03:05:00 UTC - Size: 254.65 KB - 167 views
imageBar Duration Not Working as Text Under Bar.jpg / V - Attached On 2024-12-04 03:05:15 UTC - Size: 316.88 KB - 182 views
[2024-12-04 15:40:08]
You need to set the "Value Format" for the "Study Subgraph Above/Below Bar as Text" to be "Time". Refer to the following:
Chart Studies: Settings and Inputs Tab >> Value Format
