Date/Time: Sun, 19 May 2024 21:31:44 +0000
Sim fills during Replay
View Count: 967
[2014-09-11 20:41:23] |
QnReally - Posts: 181 |
Is it possible to show the SIM or Live fills that happened during the trading session on the charts while I replay them later in the evening? I don't need to enter any new trades during the replay, I just would like to see the trades that were already executed. Thanks. |
[2014-09-11 23:48:50] |
No, this is not supported. Only fills in the Replay order fill source category will be displayed.
[2014-09-12 03:06:31] |
Is it complex on your end to implement this? Is there a risk of inadvertently sending live orders during replay if this is implemented? I can try to justify the need when you have time to weigh your options on whether to implement it or not. Thanks. |
[2014-09-12 03:14:17] |
We are not in any position at all to be taking on new tasks like this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-12 03:14:26
[2020-07-14 10:25:56] |
User156295 - Posts: 104 |
I know it is quite old but did not find anything about replying Live fills. This is so important for sessions reviews. Do you have plans to improve it and be able to reply live fills? |
[2020-07-15 20:29:15] |
This is now supported. Make sure you are running the current version: Software Download: Fast Update Follow the instructions here: Replaying Charts: Replaying Non-Simulated / Live Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
