Date/Time: Thu, 19 Nov 2026 11:17:11 +0000
no data feed
View Count: 421
| [2024-12-01 13:08:09] |
| User477346 - Posts: 1 |
Hi Support, my cqg data feed is disabled.can you advise me please. David Rogers... |
| [2024-12-01 19:26:10] |
| Sierra_Chart Engineering - Posts: 25441 |
This would be something that your broker has done. Follow the instructions below. Since you cannot connect your trading account and your trading account is disabled, at this time you are going to be getting delayed CME data. ---- To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-01 19:26:26
