Date/Time: Thu, 19 Nov 2026 11:17:05 +0000
Volume Profile Tool
View Count: 467
[2024-11-29 13:35:10]
User141735 - Posts: 14
I use the Tool Draw Volume profile.
I couldnt find a way to set the tool so that i can draw a volume profile that cover all the loaded bars in the untill a fixed point in time made by the mouse click while using the tool.
so it is a VP that cover from the oldest point in time till a fixed point in time fixed by the mouse right click.
Thank you for you support ;)
Regards,
[2024-11-29 20:58:17]
Are all of the chart price bars in the visible view of the chart?
Anyway, there is a way to do this. Refer to:
Chart Drawing Tools: Performing Drawings that Span More than the Window Width
Date Time Of Last Edit: 2024-11-29 20:58:34
