Date/Time: Thu, 19 Nov 2026 11:17:16 +0000
Plotting an RTH vwap on an ETH chart
View Count: 1722
| [2024-11-27 18:29:47] |
| User362013 - Posts: 9 |
Hello, I am trying to plot a vwap on NQ that starts at 9:30 and resets every hour on an ETH/Globex session chart. Because the session start time on the chart is 18:00, the vwap starts at 9:00 instead of 9:30. I have tried using the 'start date time' setting on the vwap to begin plotting at 9:30 but that just makes it reset at 10:00 instead of 10:30. How do I get it to plot 930-1030-1130 instead of 900-1000-1100? Thanks.
| [2024-11-27 19:10:58] |
| John - SC Support - Posts: 48583 |
The only way to do this would be to have another chart that is setup with Session Times that start at 09:30 and then put the VWAP on it as you want. Then use the "Study/Price Overlay" to overlay that VWAP to the original chart you are referencing. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-27 19:15:42
| [2024-11-27 20:34:26] |
Thank you!
