Date/Time: Thu, 19 Nov 2026 11:17:09 +0000
Chart Values Window shows not showing a bar's open, high, low, and close
View Count: 663
| [2024-11-27 16:37:15] |
| User519560 - Posts: 5 |
When I hover over a chart bar, the chart values window displays price change from the preceding bar and the current value of the indicator I am using. I don't want either. There was a time in the past when I could open a table and when hovering the chart value crosshair over a bar, I would see that bar's open, high, low, and close. But now I cannot find this capability and have not been able to find it on the Support Board. Is there still a way to hover over a bar and, probably in a window, see the current bar's open, high, and low; and for preceding bars, open, high, low, and close? Thanks. |
| [2024-11-27 18:57:10] |
| John - SC Support - Posts: 48583 |
To view just the current bar's Open, High, Low, and Close when using the Crosshair, you would want to use the "Compact Tool Values Window". Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
