Date/Time: Thu, 19 Nov 2026 11:17:15 +0000
Can you auto extend trendlines when creating them?
View Count: 924
| [2024-11-26 21:45:16] |
| Jimmyz83 - Posts: 62 |
I am using multiple time frames and charts and when I make a line that ends in the fill space it does not line up on other charts. So I read I need to make the line up to the fill space. When doing this I have to click on the line again and hit the extend function. I create a lot of lines during the day. Is there a way that when I create a trend line or parallel line, after finishing the line inside the chart, it will automatically extend to the end of the chart and into the fill space in the future? Thank you for your help |
| [2024-11-26 22:04:45] |
| John - SC Support - Posts: 48583 |
Use the Ray or Parallel Ray options. They will extend to the right and continue to do so when new bars come in. You just need to follow the same rule that you can not place an anchor point in the fill space to the right. Refer to the following: Chart Drawing Tools: Line, Ray, Extended Line Chart Drawing Tools: Parallel Rays For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
