Date/Time: Fri, 03 May 2024 16:04:19 +0000
Several values showing zero
View Count: 1220
[2014-09-11 10:21:02] |
User38813 - Posts: 20 |
sir as per chart attached values in several columns are showing zero. I tries to reload data but its remains the same. Then i contacted GFDL regarding this . They told me that it due charting platform not due to data. Please guide me through. PS Mainly this problem arises when ever i get disconnected and get login again [img]http://imagizer.imageshack.com/img674/4422/bKgOh9.png[/img] |
[2014-09-11 18:55:20] |
This is because the historical data from Global Data Feeds is in 1 minute units and it is not tick by tick. So it is not possible to determine the Bid volume Ask volume from this data. So for for the times you were not connected to the data feed, you will have zero values for bid volume and ask volume and any calculations based upon those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 07:15:04] |
User55905 - Posts: 34 |
Date Time Of Last Edit: 2014-12-10 14:01:19
[2014-11-12 08:05:05] |
2. Do I have to keep open every chart (if I work with 10 symbols, then 10 charts) continuously from start to end? You need to do this.
[2014-11-12 08:30:40] |
Okay. Got it. Another related queries: 1. When I login for the next session and thereby sessions, will the last session bid/ask volume data go and updated by 1 min GFDL data or will I get to have the yesterday's data untouched? 2. How many charts/windows can I open so that SC don't hang and miss any tick? |
[2014-11-12 08:52:44] |
1. will the last session bid/ask volume data go and updated by 1 min GFDL data No definitely not. The data will remain.2. You will have to experiment with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-12 08:52:59
