Date/Time: Thu, 19 Nov 2026 11:17:00 +0000
Detached windows, smaller tabs
View Count: 547
[2024-11-25 14:38:13]
User495734 - Posts: 48
Hi Sierra,
For the non main window page (second screen), how do I attach another chart to form tabs at the bottom? In the first picture as you can see, I have 3 tabs open for which i can toggle in between on the main screen.
On my second computer screen where I have detached 3 tabs but do no wish to squeeze them into 1 screen, can I do the same and form them into tabs like on the main screen for which I can toggle in between them?
imagemultiple tabs main screen .png / V - Attached On 2024-11-25 14:38:01 UTC - Size: 26.47 KB - 176 views
[2024-11-25 16:09:43]
TonyCipriani - Posts: 155
I think you might need to use a different instance to do that.
If you just want to have different tabs based on timeframes, you could perhaps use a control bar and put the different timeframe buttons on there which would act like tabs.
[2024-11-25 19:07:47]
TonyCipriani is correct. You can only group charts within the confines of the main window. Therefore, what you are asking for is to have 2 main windows, which would require a second instance of Sierra Chart. The easiest way to do this is to use the "File >> New Instance" option. Refer to the following:
File Menu: New Instance (File)
