Date/Time: Thu, 19 Nov 2026 11:17:02 +0000
Restore a chart window
View Count: 510
| [2024-11-25 00:59:04] |
| User14953 - Posts: 268 |
How is a chart window restored to any size less than "maximized"? My restore button and the maximize button top right both result in the minimized chart window being inconveniently maximized. |
| [2024-11-25 01:22:08] |
| Sierra_Chart Engineering - Posts: 25441 |
If you are using this setting, the restored size of a window is not going to be remembered: General Settings Window: Use Alternate Window Placement Method (Global Settings >> General Settings >> GUI >> Application GUI) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
