Date/Time: Thu, 19 Nov 2026 11:17:02 +0000
ID#.SG#@Row# format fails to realign references.
View Count: 501
[2024-11-24 19:52:38]
Sawtooth - Posts: 4361
I built a system with 60 Formula Columns, but only used 28 so I reduced the setting to 30 Formula Columns.
ID1.SG1@3 was in column BS, but now is in column AO, as expected.
Everything appears correct.
However, when starting a Replay Chart, the displayed subgraphs are not where they belong.
If the Formula Columns setting is returned to 60, all is well.
A workaround fix for this to work with 30 Formula Columns:
- change O3 from =ID1.SG1@3 to =AO3 (references resumed proper alignment)
- then change O3 from =AO3 back to =ID1.SG1@3 (references retained proper alignment)
Please advise.
Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study
[2024-11-25 03:22:29]
We will check this.
