Date/Time: Thu, 19 Nov 2026 11:25:24 +0000
Eliminate study name in regions
View Count: 461
[2024-11-22 16:23:53]
JohnR - User831573 - Posts: 340
I have a chart the uses the Overlay study to get the same study from different charts (timeframes). I want to eliminate the study name line, for each of them. As you can see in the Chart Values for Tools window of the original chart, they do not appear. I have tried both options on the overlay study Yes_No for "Use Subgraph name/Value related Display Setting from Source Study"
Update - reg 5 is using the same study but for local chart - not using Overlay study. It does not have the study name line.
Guidance appreciated
JohnR
Date Time Of Last Edit: 2024-11-22 18:49:07
imageSC_ChartValues4ToolsWindow_SourceChartToolsWin.jpg / V - Attached On 2024-11-22 16:22:34 UTC - Size: 60.43 KB - 198 views
imageSC_ChartValues4ToolsWindow.jpg / V - Attached On 2024-11-22 16:22:45 UTC - Size: 338.11 KB - 179 views
[2024-11-22 19:17:47]
On the "Study/Price Overlay" you need to disable (remove the checkmark) for the entry on the Subgraphs tab for the following:
- Display Study Subgraphs Name and Value - Global
- Display Study Name
- Display Input Values
These items are not copied from the source study. Refer to the information for these items starting at the following:
Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global
