Date/Time: Thu, 19 Nov 2026 11:25:15 +0000
Filled Bracket Orders Alerts
View Count: 513
| [2024-11-22 02:10:54] |
| socaltrader - Posts: 24 |
after shutting down the computer while there are (Server Side) Open Positions, is it possible to get alerted/notified when the TP/SL bracket orders are filled?
| [2024-11-22 02:25:38] |
| Sierra_Chart Engineering - Posts: 25441 |
No this is not possible if Sierra Chart is not running.
| [2024-11-22 03:06:21] |
may I know how to implement this feature while Sierra Chart is running?
| [2024-11-22 14:55:26] |
| John - SC Support - Posts: 48583 |
Refer to the following and the item below it: Global Trade Settings Windows: Play Alert When Target Filled (Global Settings >> General Trade Settings >> Notifications) Also refer to the following for how to configure an alert: General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-24 18:40:00] |
You can have these alerts, sent to the Sierra Chart mobile chat application. Which can be used to alert you on a mobile phone or other devices: Chat and Communications Platform: Using Chat for Remote Alert Notifications Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-24 18:40:01] |
