Date/Time: Thu, 19 Nov 2026 11:25:29 +0000
Apex Rithmic Accounting
View Count: 568
| [2024-11-21 13:59:14] |
| User993067 - Posts: 200 |
yesterday there was a rithmic outage around 11:30 est. SC would not respond so I had to exit directly within Rithmic. now my SC accounting has missed that fill ( sc thinks the next order I placed in SC was the exit from the position I closed in rithmic) so the accounting is totally screwed. off by 2k for the day. How does this get cured? Need to run excel analysis.
| [2024-11-21 15:40:23] |
| John - SC Support - Posts: 48583 |
You need to enter the missing order fill manually in your Trade Activity Log. Refer to the following: Trade Activity Log: Manually Inserting Missing Order Fills Or you can set the "Chart >> Chart Settings >> Trading >> Order Fills Start Date Time" to be after that fill would have occurred, so when you were flat in the market. In this case, your Daily P/L will be correct, as the previous fills will be ignored. Refer to the following: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
