Date/Time: Thu, 19 Nov 2026 11:25:12 +0000
Quotation frozen - no data feed
View Count: 466
| [2024-11-21 10:41:13] |
| User344481 - Posts: 2 |
Hi, Since yesterday morning my charts are frozen and the last quote I can see is the one updated when I log in. It seems like a pause. My feed is with Rhythmic. I have already disconnected and reconnected, I have changed the feed for Sc all data feed, I have updated the last version of Sierra Charts but nothing solves my issue. I can't see the data in real time. Can you help me ? Many thanks. Best regards |
| [2024-11-21 14:30:56] |
| Sierra_Chart Engineering - Posts: 25441 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
