Date/Time: Thu, 19 Nov 2026 11:25:17 +0000
Déplacer un chart
View Count: 1161
| [2024-11-20 10:46:13] |
| User914407 - Posts: 65 |
Bonjour, comment déplacer un graphique sierra chart de haut en bas et de droite à gauche avec la souris ? Merci |
| [2024-11-20 16:44:33] |
| John - SC Support - Posts: 48583 |
From Google Translate: Hello,
how to move a sierra chart up and down and right and left with the mouse? Thanks You would use the "Hand" tool to do this. There is also a setting you need to check to ensure the Hand tool is setup to allow for vertical movement. Refer to the following: Chart Drawing Tools: Hand Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-21 09:20:17] |
Merci Autre question : comment faire en sorte que le graphe Market Profil ne s'agrandisse pas ou ne se reduise pas lorsque je le bouge avec l'outil main paramétré pour pouvoir bouger le graphe de haut en bas et de gauche à droite ? |
| [2024-11-21 14:56:08] |
From Google Translate: Thanks
Another question: how do I make sure that the Market Profile graph does not get bigger or smaller when I move it with the hand tool set to be able to move the graph up and down and left and right? The TPO profiles should not change size when moving the chart with the Hand tool. The only time the TPO profiles should change size is if you are changing the axes spacing by changing the bar spacing or the price spacing. Is this occurring with the scroll wheel on the mouse and not the Hand tool? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-21 16:32:27] |
Pourtant si ... Lorsque je fais glisser le chart horizontalement avec l'outil main (pas la molette), les profils bougent de place verticalement et aussi de taille |
| [2024-11-21 17:46:56] |
From Google Translate: Yet if ...
When I drag the chart horizontally with the hand tool (not the wheel), the profiles move vertically and also in size Sorry, we do need to amend what we stated. If the scale is set to "Automatic", then as you move the chart with the Hand, the scale will change in order to fit the profiles on the screen. This is true for any scrolling method with Automatic scaling. If you do not want the scaling to change, then set the scaling to either Constant Range or User Defined. Refer to the following: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
