Date/Time: Thu, 19 Nov 2026 11:25:16 +0000
Problem with data - Continious Futures
View Count: 511
| [2024-11-19 17:38:20] |
| User914828 - Posts: 36 |
I have problem with data - number bar on the chart, how Can I increase number of bar in the chart, previous series contract
| [2024-11-19 23:00:16] |
| John - SC Support - Posts: 48583 |
Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-19 23:00:21] |
| Sierra_Chart Engineering - Posts: 25441 |
Increase the Days to Load setting: Chart Settings: Days to Load for Historical Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) And then re-download the data if necessary: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
