Date/Time: Thu, 19 Nov 2026 11:25:20 +0000
lenteur
View Count: 564
| [2024-11-19 10:17:03] |
| User914407 - Posts: 65 |
Bonjour, Sierra met bcp de temps lors du lancement de l'application. Sur quels parametres puis-je intervenir ? Merci |
| [2024-11-19 16:48:08] |
| John - SC Support - Posts: 48583 |
From Google Translate: Hello,
Sierra takes a long time to launch the application. What settings can I change? Thanks What exactly is taking a long time to launch? Is it the application itself, that is the time from when the Login screen goes away until the application comes up (before any data is loaded)? Or is it the amount of time it takes to load data? Or something else? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-11-19 17:22:57] |
C'est le temps pour charger les données
| [2024-11-19 17:29:46] |
There is a lot that goes into loading the data, so we really can not comment on what you may believe is a long time. Refer to the following for what information we have on improving load times: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
