Date/Time: Thu, 19 Nov 2026 11:25:11 +0000
Using DTC protocol for data, but send orders to a different broker
View Count: 722
[2024-11-17 18:38:46]
RetardedJimSimons - Posts: 102
Main instance of SierraChart has broker A with DTC server enabled.
Multiple independent SierraChart instances connecting to main instance with DTC to use data but wanting to send orders to broker B,C,D.
It seems like this setup is not supported or at least I couldn't connect the dots on how to do this from the documentation.
What's the right way to do this?
The documentation I read: Using DTC Server for Data and Trading in Another Sierra Chart Instance
Thanks.
[2024-11-18 03:43:35]
This is not going to work due to exchange rules:
So you cannot do what you want as you describe.
However, look at what is supported here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Date Time Of Last Edit: 2024-11-18 03:44:00
