Date/Time: Thu, 19 Nov 2026 11:25:24 +0000
[User Discussion] - Idea for future implementation
View Count: 813
[2024-11-17 00:33:56]
TradingInDemand - Posts: 29
Hello, I was wondering if it would be possible to add extra label columns and a study/ ability to easily add labels by right clicking and choosing from the drawing menu. Similar to the ECI Anchor VWAP. Bookmap has a similar implementation and helps declutter the price labels
Thanks for you time
[2024-11-18 15:09:38]
There is a "Label" column already that can be used instead of placing the labels in the Price Ladder. And there are two "General Purpose" columns that can be used by custom studies. Refer to the following:
Chart Studies: Subgraphs Tab >> Name and Value Labels
ACSIL Interface Members - Functions: sc.GetDOMColumnLeftCoordinate()
[2024-11-18 18:33:30]
Yes I was commenting on adding an “Extra” label column. Would there be any way to use the general purpose columns with non custom studies?
Also is there any consideration into being able to easily add labels to the column besides using the “horizontal line” study?
[2024-11-18 21:31:59]
Those extra columns can only be accessed with a custom study. There are no studies that are in the system that use those. And there are no other columns that can be used like the Label column.
There is no other way to get a label into the Label Column other than by using a study. The "Horizonal Lines" study is probably the easiest one to use to set a particular Name/Value in the Label column where you want it.
Otherwise, you could create a custom study that let's you enter a price level and a name to put in the Label column. It could be a little easier to use as you could just have a series of "Price" and "Name", rather than having to set them up through the Subgraphs on the Horizontal Lines study. Refer to the following:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].LineLabel
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2024-11-20 03:36:28]
Is there any consideration to add “general purpose 1” as an option when selecting name + price label location? Seems like an easy implementation that would greatly improve the user experience.
Thanks for your time
