Date/Time: Thu, 19 Nov 2026 11:43:13 +0000
Unable to Connect to Rithmic Prop Firm
View Count: 621
[2024-11-07 08:05:46]
aygh - Posts: 22
I'm having trouble connecting to my Rithmic prop firm account (flexytrade). I've done this before with Apex and it went smoothly. Under Server List I dont have any options in the dropdown menu anymore. How do I fix this?
imageRithmic.jpg / V - Attached On 2024-11-07 08:03:14 UTC - Size: 100.43 KB - 243 views
[2024-11-07 15:39:54]
Refer to steps 8-10 at the following link:
Rithmic Trading Platform Service: Setup Instructions
[2024-11-08 03:46:50]
aygh - Posts: 22
Hello John,
I was able to figure out the server. It was the first option. Now my issue is that I can't place any trade and I dont know why. I've attached my Trade Service Log
Date Time Of Last Edit: 2024-11-08 03:47:06
imageLog.jpg / V - Attached On 2024-11-08 03:46:19 UTC - Size: 277.98 KB - 171 views
[2024-11-08 14:40:00]
According to your log, you have the option for "Trade >> Trade Simulation Mode On" enabled, but you have your live account selected. Therefore the system will not put in a simulated order since the account is wrong.
On the other hand, if you want to submit your order through Rithmic, then you need to turn off the option for "Trade >> Trade Simulation Mode On".
Refer to the following:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
