Date/Time: Thu, 19 Nov 2026 12:15:22 +0000
Data feed for a second system
View Count: 732
| [2024-10-17 18:13:05] |
| User509533 - Posts: 99 |
I currently have a subscription to the full real-time CME Group data feed in Sierra Chart. I want to run Sierra Chart on another system using only the top-of-book CME data. Can I subscribe to a lower-cost top-of-book CME data plan for use on the second system?
| [2024-10-17 18:38:11] |
| John - SC Support - Posts: 48583 |
Unfortunately, this is not the way it works. You have to pay a second set of exchange fees for the exchanges that you have active. There is not way to have one system getting data for "The Full CME Group" and another for the "CME top-of-book". Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-17 19:07:28] |
Thank you. Whats is the bare minimum Sierra Chart subscription option to support top of the book CME or CBOT? I was thinking of creating a new userid/account. |
| [2024-10-17 22:13:43] |
The lowest cost option would be the "Integrated Standard" package (package 10). The cost for this is $36.00 per month. Then the cost for the exchange is $2.00 per month. Doing this would be slightly cheaper than paying double the exchanges fees, but only because you also have the U.S. Equities Consolidated Tape. Also, keep in mind, this is only an issue if you are using the computers simultaneously. If you will only be on one or the other, then as long as you exit Sierra Chart when you are done on a system, then you do not need anything additional. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
