Date/Time: Thu, 19 Nov 2026 12:23:21 +0000
Not getting any data
View Count: 601
| [2024-10-04 16:00:15] |
| User321619 - Posts: 26 |
Currently using Apex evaluation account. Want to use Denali Data Feed. Activated the feed. Created external trade account. Connected and activated trade account. Switching back to "Rithmic Direct - DTC" in Data/Trade service settings in Sierra Chart. After this am getting no data. It stopped, it was working before I did above steps. Need help. Thanks |
| [2024-10-04 17:03:13] |
After I put in "Market Data Username" and "Historical Data Username" and passwords, the data started again. However still seeing [C] next to mini contract name. It means am not getting Denali feed. Please suggest. Thanks. |
| [2024-10-04 17:10:37] |
| Sierra_Chart Engineering - Posts: 25441 |
You have not activated any exchanges. You need to do that: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-10-04 17:19:57] |
Thanks for your response. I just realized and activated. Now, I see [C][M] both next to mini contract. Is that correct, or should see just [M]? Thanks. |
| [2024-10-04 17:57:30] |
| John - SC Support - Posts: 48583 |
The [C] means the chart is a Continuous Futures Contract - Date Based Rollover. Refer to the following: Continuous Futures Contract Charts: Text Indicator Description Table For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
