Date/Time: Thu, 19 Nov 2026 12:57:37 +0000
Candlesticks don't move in Realtime / Tick by Tick
View Count: 731
[2024-09-09 14:36:48]
Mr.Adio - Posts: 18
My Candlesticks don't move Tick by Tick, they update like all 5 Seconds, it looks like they take an average value & don't really move. Strangly when i disable "Allow Support for Sierra Chart Data Feeds" the Candlesticks then move tick by tick, why is that? When i disable this option it doesn't load any historical movements...
I have open a Tradingview Chart on my other screen & there you clearly can see the price move in realtime, each tick. While the one on Sierra just moves all couple of seconds
[2024-09-09 18:12:18]
Refer to the following for things to check:
Prices / Data Falling Behind
