Date/Time: Thu, 19 Nov 2026 12:57:11 +0000
retracement tool
View Count: 513
| [2024-09-08 15:14:50] |
| LAdisa - Posts: 17 |
Hello, how do I adjust the size of the retracement tool? Make it larger to see on my chart. Thanks.
Attachment Deleted. |
| [2024-09-09 14:25:53] |
| John - SC Support - Posts: 48583 |
You change the lines size and type through the properties/configuration for the study. Refer to the following: Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties To change the text size, you need to change the Global Chart Drawing Font. Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
