Date/Time: Sat, 12 Jul 2025 00:47:38 +0000
bars are not keeping up with price on my VWAP daily chart
View Count: 263
[2024-09-05 17:50:32] |
User224963 - Posts: 17 |
I am new to Sierra, but I did scroll completely to the right at the bottom of the page, but candles are still not forming as price moves. How do I correct this? Please and thank you! |
[2024-09-05 20:22:43] |
John - SC Support - Posts: 40857 |
What is the symbol of one chart for which you are having an issue? Also, depending on the symbol, you may be getting delayed streaming data. In this case, when the system downloads any missing data at the beginning of the data, or when there has been lapse in connectivity, it will download data to the current time. Therefore, you would have to wait 10 to 15 minutes (depending on the exchange) for the delayed data to "catch up" to the downloaded data. This is normal, you just have to wait for the time to pass. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-06 00:06:25] |
Thanks so much for responding! I'm waiting for data on the ES Emini S & P 500
[2024-09-06 13:53:38] |
If you have waited more than 10 minutes and the data is still not moving, then refer to the following: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
