Date/Time: Wed, 11 Feb 2026 16:25:27 +0000
Assistance required to resolve trade order error
View Count: 423
| [2024-09-05 17:15:05] |
| User395564 - Posts: 1 |
Dear SierraChart Support Team, I hope this message finds you well. I am encountering an issue with my trade orders and would appreciate your assistance in resolving it. I received the following error message: "2024-09-05 17:04:10.950 | Trade Order Error - The order quantity for the Parent is 1 and this is less than the total order quantity of 2 for the Attached Orders. Adjust the order quantities so the parent is greater or equal to the Attached Orders." It seems that the Parent order quantity is smaller than the total of the Attached Orders, but I'm unsure how to properly adjust these quantities to avoid this error. Could you please guide me on the correct steps to resolve this issue? Thank you for your help, and I look forward to your response. Best regards |
| [2024-09-05 17:15:51] |
| John - SC Support - Posts: 44575 |
You adjust your Attached Orders on the "Targets" tab of the Trade Window. Refer to the following: Attached Orders: Using Attached Orders and Attached Order Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
