Date/Time: Wed, 17 Dec 2025 07:07:36 +0000
button for the control bar to change time frame windows that is already open
View Count: 454
| [2024-09-05 16:51:38] |
| Dave - Posts: 8 |
I am also trying to add a button for the control bar to change time frame windows that is already open - instead of me having to scroll the mouse down and select the desired timeframe from the pop up - is that possible? The current control button causes the current window to load the new time frame I just want to be able to switch/tab through the windows by clicking on the button.. |
| [2024-09-05 17:46:14] |
| John - SC Support - Posts: 43500 |
We are not understanding what you are asking for. You can change between windows by selecting the "Previous Window" or "Next Window" options, which are set keyboard shortcuts of F4 and F9 respectively (by default). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-05 21:01:12] |
| Dave - Posts: 8 |
Let’s say I want to change from 1min to 10min time frame on the control board; if I have the button set and click it, the screen will load the 10min timeframe - instead I just want it to open the window which already has the 10min timeframe. Exactly like your instructions above but instead of pressing f4 or f9 I can click the 10min button on the control board |
| [2024-09-05 21:12:35] |
There is not a way to select a button or a keyboard shortcut to go to a specific chart. The closest available is an option for "Go To Chart Number", which will let you type in the chart number after you select it.
