Date/Time: Thu, 19 Nov 2026 12:57:15 +0000
Alert Mgr and Message Log windows
View Count: 521
[2024-09-05 11:24:44]
User14953 - Posts: 268
On startup why recently do the Alert Manager and Message Log windows stack up in the top left corner of the screen covering the File and Edit commands?
This requires they be individually moved every time Sierra is started up.
Why don't the Alert Mgr and Message Log windows remain placed where they were from when Sierra gets shut down
and how can the user correct this situation?
Date Time Of Last Edit: 2024-09-05 11:25:37
[2024-09-05 14:59:41]
These windows open in the same position they were in when you exit Sierra Chart. The only thing we can recommend is to try the following setting:
General Settings Window: Use Alternate Window Placement Method (Global Settings >> General Settings >> GUI >> Application GUI)
[2024-09-05 23:17:33]
Finding that if File > > Save All is used before Exiting, the Log and Mgr windows open in the same position they were in when Sierra was exited.
